RE: Installing a YS63 in Flip 3D???
This entire thing turned out to be a piece of cake. I mounted the engine inverted, flip the throttle arm over so it was pointing down (really up) installed the servo tray and servo in stock position. the throttle rod runs perfectly straight to the carb arm just below (above) the wing. I have no idea why they suggest mounting a 4s at 90 degrees.
Steve
