RCU Forums - View Single Post - Setup/Mods to Kyosho Flip 3D
Old 06-01-2004 | 10:37 AM
splais
My Feedback: (25)
Default RE: Setup/Mods to Kyosho Flip 3D
I have read a ton of stuff also. Haven't found but a few comments relating to my idea. If you haven't started yours yet be careful of two things:
(1) If you mount the tank on CG you will find that the servo tray mounts to low and interferes with the tank stopper going through the nose ring. I fixed it by notching the back of the servo tray. worked great.
(2) Mounting the wing turned out to be a b****. Getting the holes to lineup when you put the reinforcing plate on the wing bottom was a mess. I ended up messing with it for half an hour with a dremel tool before I could get the wing bolts in.
