RE: Help! engine problem?
The weather will definatly cause a tuning issue, and also being at a different elevation. Actually with the hot and humid days you get in texas, it needs to be a little leaner mixture. I could almost guarentee that your low / high end is a little to rich.
Start with the high end needle set first then work you way to the low end until you get a good transition.
