RE: centre slipper diff for dominator
thanks for the info i will give it some thought.
so you recommend the single slipper centre diff as it will make the car handle better off jumps and also make the front and rear diffs last longer. i have a dom extreme version with all the alloy bits and pieces.so it should last a little longer than most standard doms or pirate mt's.
anywayz thanks for the info [sm=biggrin.gif]
