RE: Aerophibian float plane on sale for $119.99
Got mine intially when they had a sale for $99.Flying it with a Mag 52 4 stroke works real nice only flown on land but have the floats on it now looks like should do well is nice on wheels very capable little plane,all simple stunts etc Added a cover on front wheel to match theother 2.Only complaint is that have to take the cowl off which necessitates prop and needle valve and about 6 screws to remove the nose wheel to convert it to water but no big deal just takes a little longer.I ran rod directly from permanentlymounted servo in belly to the rudder then in switching back will just remove the rod.I don't care for the different linkage deals have used this makes a direct connect.Good luck!
