RE: Shaking
I agree with Spaceman, loose linkages , worn dampers( rubber Grommets inside the main blade holders), also check the paddle blades , first that they are pointing the right way and secondly that the distances from the ends to the middle point of the main shaft are exactly the same. good luck
