RCU Forums - View Single Post - Reaper: magnitude for control surface throws?
Old 06-04-2004 | 01:53 AM
Propellars's Avatar
Propellars
Default Reaper: magnitude for control surface throws?
Hi all, I have been flying my Super Reaper 3 times now, and I think its very sensitive on the elevator at high speed.
My control surface throws are:
Canard: +/- 25 mm (1 inch) and Ailerons (elevator) +/- 15 mm. Exponential 45%
The reaper is powered with a 32 lbs (14,5 kg) Frank Turbine turned down to 22 lbs (10 kg).
CG is right on the original spot, weight is appox 10.5 kg / 23 lbs wet.
What are your control surface throws on canard and ailerons?
