RE: Reaper: magnitude for control surface throws?
I have a Ram 750P which can put out 22lbs, but I am fly it on only 12lbs currently. My throws are setup in the following:
Canards: + 30mm / - 25mm
Aileron: + / - 20mm
Elevator: + / - 10mm
CG: 21.5"
Keep in mind I setup my Reaper like a Delta type jet with elevons too. I originally had the CG set to Mick's recommendation ( 530mm from the back) but it was very pitch sensitive. So I moved it forward to 21.5" from the back. Also, I add some downward thrust to the turbine which seems to also make it fly better at higher speeds.
JR Gautreaux
