RCU Forums - View Single Post - hinges on speed planes
Old 06-04-2004 | 10:40 PM
rockhouse's Avatar
rockhouse
Default RE: hinges on speed planes
On my ARF Magnum I used the supplied CA hinges. On my DD I use CA's but install them prior to covering. Then I cover the wing & aileron as a unit, deflecting the control surface away from the side I'm covering. This gives me a sealed hinge line that will not pull out, flutter, or fail.
