RCU Forums - View Single Post - Avistar 40 Select RTF CG
Old 06-06-2004 | 07:51 AM
TNRabbit's Avatar
TNRabbit
Default RE: Avistar 40 Select RTF CG
Are you balancing with the fuel tank empty or full? What are the throws on your elevator? (full and dual)
One option to get rid of some of the weight is to build an access panel about 1/2 way between the tail and rear of the wing and install your battery there. I have a 4*40 I did this with and saved adding a lot of tail weight.
