RE: Avistar 40 Select RTF CG
I put my CG at 3" or between the two suggested balance points and it flys fine. Another thing to do, is epoxy in the horizontal stab and verticle stab. Also cut off the wires on the vertical stab with a dremel tool and cut off wheel at the balsa.
