RE: Dave Patrick Edge 540 Rudder throw problem
binghamjd:
I have the same problem on mine but I've got mine figured out. check the horz stab and make sure it's completely flush to the side of the fuse. on mine the front rod needed to be bent slightly to make the fit right. once everything fits tight there is plenty of room for travel. let me know if this explanation is not clear enough and I'll try again.
Miloh.
