RE: Starter box on Pullstart
As long as you spin it the correct way as Tjnmt said you will be fine, if you spin it the wrong way to will thrash your pull start and possably one-way bearing, and the motor wont start either. Just rember to make shure the doughnut is mounted very good to the starter, glue it and bolt it if possable, they realy fly across the room if they come loose and hurt bad[:@] Yes I know first hand LOL
