RCU Forums - View Single Post - Dynaflite Talon build
Old 06-09-2004 | 12:38 AM
WORNBOOTS's Avatar
WORNBOOTS
My Feedback: (33)
Default Dynaflite Talon build
Just to add to the RCU database, I thought I would post this build.
Anyway after completing the Kougar, Danny Joe (Boo) My 4 year old Wants his plane built.
First off I bought it through RCU, had a good deal with the seller and all went well (thank's RCU Market and the Seller)
I'm not goig into sub-componet assembly just the major componets, so this first post will be of the rough and ready fuse completion.
All went well with the basic build and layout of the fuse, though the manual is pretty good and folowing it was straight forward, the curves formed by the fuse sheeting are a bit tough to keep aligned but not a major prob. just chech & re-check before gluing.
I found that aligning the upper sides with the formers / blkhds were critical. As well as keeping the fuse middle flat on the table as required when installing the blkhds.
I stuck a t-pin through the fuse sides flush with the front of blkhd#3 out each side so I had a tiny hole for an exact ref to where the cut ot was going to be.
So far so good, Boo learned a little more about building and sweeping up balsadust.
ID:	141281   Click image for larger version
ID:	141282   Click image for larger version
ID:	141283   Click image for larger version
