RE: H9 Twist 40 engine/thrust line setups
I have an OS 50SX on mine mounted straight ahead with an APC 12.25-3.75 prop and the plane is balanced at 5" from the LE. I think it needs a little right thrust. It wants to go off to the left when you gag it. I'll try shimming the LH mounting beam by this weekend.
