RCU Forums - View Single Post - 4* 60 replacement wing ??
Old 06-10-2004 | 07:38 PM
phread59
Default RE: 4* 60 replacement wing ??
Ryan, not a problem. You can do it 1 of 2 ways. Use the old sheets where you punched out the parts as a template. just get some new wood and cut the parts out. At this stage the only pieces I think you would have used is balsa. So a sharp hobby knife is all you need. The other way is to punch out the other parts and use them as a template.
This method will work a little better. You make the parts slightly oversize. And sand them to final shape.
It should be an easy fix. Good luck with your kit.
Mark Shuman
