RCU Forums - View Single Post - I need help!!!!
Old 06-11-2004 | 07:40 PM
phread59
Default RE: I need help!!!!
My reccomendation is to go to a club or flying field and ask for some help. The AMA's web site has te info on it you need to contact clubs in your area. There is so much you need to know. It is so much easier face to face. most clubs have people in it that would love to help you out. You will also get to know some nice people. Anyway you will get more help and quicker this way. If this is not available to you try posting individual questions here. You will get better answers. It will help us solve your problems easier. Good luck and welcome to the hobby and RCU.
Mark Shuman
PS: to unfreeze the engine. Try taking the glow plug (the hex head device with a pin in it on top of the engine)out. Take some penetrating oil or fresh fuel and put some down the hole. Open the carb up (use the little arm on the round inlet at the front of the engine) and put some in there as well. let it sit overnight and try to work it loose. Keep trying this until it spins free. If it will not then seek help. The servo's go in the cabin under the wing. They will mount on ether rails or in some kind of wood tray. If these are not there you will need to install a tray. You then hook up the control rods to them.
One last thought. See if there is a local hobbie shop in your area. Usually the proprieters can help you. Or point you too someone who can. once again good luck.
