RE: Sterling Stearman ?s
Very cool!! Exactly what I was looking for. You must have used an after-market motor mount. Mine has the wood beams (which I can cut off). The firewall hasn't been glued on. What would you recommend for a two-stroke? I'm wondering how much more of the dummy radial I'd have to cut out for a pitts muffler.
The problem with the hinges are that they are epoxied in as well as pinned through the wood. I need to cover the tail surfaces w/o being able to wrap the covering around and then paint the wood that is not covered (?).
Any more pics out there?
Thanks again!
