RCU Forums - View Single Post - Hovering on Real Flight G2
Old 06-14-2004 | 12:43 PM
  #41
iflynething
Default RE: Hovering on Real Flight G2
I'll say my $.10!! ()....
Well, I have to say that I can hover that Double sized Cap 232......but if you look at the engine, it is a Super Tigre 4500 (it might be another one: the one on page 3)....but if you look at the engine....you will see that you have a 4500 that only weights 1.4 lbs. (well on the one I d/l anyways)......but if you have any other engine on there....and use it stock, then you can hover.....for some reason, you can't use the stock because they are too heavy or something.....
Well, in realy life......you can make a Super Tigre 4500 or larger engine for the plane weigh only 1.4 lbs. That, you just are not able to do.....
So, is there a plane that you can use a STOCK engine w/o the modifications like lowering the weight, where it WILL hover just like in real life.....
