RCU Forums - View Single Post - Setup tips needed
Old 06-14-2004 | 05:16 PM
samcim's Avatar
samcim
Default RE: Setup tips needed
no camber in the rear helps alot, also worn out tyres on the back helps too. stiffer springs in the rear, lower the ride hight in the rear, lower your shocks ( most inner hole on the shock tower on the top holes, and most outter on the lower arm)
cant think what else atm
