RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Setup tips needed
Old 06-12-2004 | 08:48 PM
Default Setup tips needed
I race on a grass "track" with another 1/8 buggy. I have trouble making turns at any speed b/c the buggy tends to flip over. Is there any setup tips/tire suggestions that will allow a certain degree of sliding of the rear to allow me to swing the front around for quicker turns?
FYI, I have an XTM X-Terminator.
Old 06-12-2004 | 09:19 PM
lax195's Avatar
Default RE: Setup tips needed
use a harder compound tire.
Old 06-14-2004 | 03:22 AM
We race on grass all the time here in the UK, you need minimum droop, slightly stiffer shocks, minimum toe out and tyres designed for running on grass eg Medial Pro Turbo Rats
Old 06-14-2004 | 08:55 AM
I havn't seen those tires anywhere, can you give a link? Thanks
Old 06-14-2004 | 11:30 AM
Maybe you can only get them in the UK.
http://www.medialpro.com/english/produits/pneus/8tt.htm
Old 06-14-2004 | 05:16 PM
samcim's Avatar
no camber in the rear helps alot, also worn out tyres on the back helps too. stiffer springs in the rear, lower the ride hight in the rear, lower your shocks ( most inner hole on the shock tower on the top holes, and most outter on the lower arm)
cant think what else atm
Old 06-14-2004 | 05:20 PM
Thanks guys, I'll try these tips out and report back
Old 06-14-2004 | 10:55 PM
dryvr's Avatar
ofna has a tire called the excel which is great for grass. Set your droop to arms level. I would run with front toe set to 0 degrees with 0 degrees of camber. In the rear one degree of toe in and one degree of camber. I would use medium rate springs.
