RE: GET THE LEAD OUT!
Reagarding the lead.. Can you drill a hole through it and screw it to the firewall ?...
I usually use one long engine mounting bolt on the front of the engine and then if
I need small amounts of lead I drill out the lead and put it on the bolt... This puts
the lead about as far forward as possible and makes full use of the weight...
