RCU Forums - View Single Post - Helicopter direction problems
Old 06-15-2004 | 03:02 AM
DarkStaR6's Avatar
DarkStaR6
Default RE: Helicopter direction problems
When you push the RH stick away from you the swashplate should tilt forward. push stick left and swash goes left, back - back ect.... If not then you need to reverse the channels on you controler until the swash plate follows the moves of the RH stick.
