Helicopter direction problems
BC, CANADA
I just got my hunmningbird elite trimed out (rudder wise) but each time I want to forward to try and get the hang of it it does not want to go where I tell it to go eg. If I tell it to go forward it goes to the back and left and so on. can any body help me with this problem.
when you push the right stick away from you the swashplate should tilt forward. push stick left and swash goes left. if not then you need to channel on you controler
When you push the RH stick away from you the swashplate should tilt forward. push stick left and swash goes left, back - back ect.... If not then you need to reverse the channels on you controler until the swash plate follows the moves of the RH stick.
BC, CANADA
Well thanks guys I did that and saw my problem. My servo wires were the wrong way around lol. Thanks a billion guys.
