RCU Forums - View Single Post - ???Charging problem?...??
Old 06-15-2004 | 05:52 PM
Righty's Avatar
Righty
Default RE: ???Charging problem?...??
ORIGINAL: skate5290
i have a JR radio and accidentaly left it on all night long i just went to go charge it and hte power indicator said zero so i was like ok i will charge it and it will be fine. i have the stock charger for rx and tx... hte rx was light up indicated it was charging but the transmitter light was not lighting like when it is charged i think there is not enough charge in hte transmitter to start charging...
what should i do????
all help is appreciated
HAPPENED TO ME!
I did i stupid thing when checking my charge and plugged it in the the Rx side. plus it has also happened for no aparent reason. I'm will to bet your fuse is blown! if you opend the back of your Tx and you will see the circut board with a little small glass tube thingy with mettal caps on the ends. you can pop it out and see that it is probably burnt, When i first did this i brought it to my LHS and they showed me what i did and gave me a new fuse. There about $4.00 up here in Canada. I always keep a spare fuse in my flight box now, cause you never know!
