RCU Forums - View Single Post - Taildragger as first plane?
Old 06-16-2004 | 02:41 PM
touch and go
Default RE: Taildragger as first plane?
The learning curve is about the same. On landing, however, you've got to maintain control after the plane touches down, with the rudder primarily, until the plane slows to a speed at which a ground loop is unlikely. If you are flying from a grass runway, then by all means go for the taildragger.
