TF Cessna 182 Engine HELP
i just started a scale projet my first scale project and i'm trying to deside what engine to run i would like to run a 4 stroke the larger ones if posable but on the plans the show the cowel cut for clearance i don't want to cut the cowl so i was going to go 2 stroke well still have to cut cowl but if i invert the engine i should be good. well here is the question i was looking at th OS FT 120 and it is set up perfect for this plane a flat twin similar to the real thing carb on the bottom at a 90 ooo i'm in heaven now will this engine fit in the cowel or will i have to cut the cowl?????
Thanks For the help
