RCU Forums - View Single Post - Houston, we've had a problem!
Old 06-17-2004 | 12:18 PM
ksechler
Default RE: Houston, we've had a problem!
It's fairly common to remove a little wood from the trailing edge to give the torque rod sufficient clearance. You could also bend the torque rod some. Check yours. The bends should be 90 degrees. If they are then go ahead and cut some of the trailing edge away.
