Remove the tire, remove the wheel hex & pin locked down the CVS, then remove the upper suspension arm. After that, you ahve full access to the CVS and you will be able to just pull it right out and install the new one in. Very easy and straight forward
so hows the acceleration on it compared to most 1/8 mt?
I would just say this, you will be amazed by the .46 engine. It might not be the fastest MT out there, but it definitely have more power than anything out there.
