RE: frequency problem...
Is there a law that prohibits you from using 72 mHZ equipment? If not, enjoy it, since you will not be competing with others for the same "channel". On the other hand, if 72 mHz is reserved for other uses (cell phones for instance) don't do it because you could loose your plane (or get a fine, I suppose)
Luis
