RE: Change to Synthetic Fuel
Crank it up and run it through its full range.Adjust the needle as needed.
If it's a little lean, you won't hurt it by running it for the few seconds that it takes you to adjust it.
If it's too lean, it will just quit. if it does, open the needle and try again.
