ORIGINAL: savage-mbx5
dont get me wrong. it works if grahama 89 says it does. but all i can say is
what a mess!!! should you really have to do that to a £400 car. that should of been done right first time from the factory
You know it works. But yes the point is when you get a car you expect it to work. The H21 does for a while, then it seems to lean itself out and thats when the probs started. I have done this on about 20 engines now and not one of them has had a problem since. This may also benefit other carbs as even the most expensive can rattle screws loose.
