RE: Homelite 33cc Ignition?
Put the feed tube onto the bigger tube on the carb, and block off the narrower tube. I usually pinch it off and sweat solder it closed to seal it. You could also put on a short piece of tubing and plug it.
If you got the needles out of whack now, just set them at 1-1/4 to 1-1/2 turns out and start from there.
Here's a picture of how mine is set up.
Jim
