RCU Forums - View Single Post - Capiche 50
Thread: Capiche 50
Old 06-20-2004 | 10:29 AM
  #3850
Shahid's Avatar
Shahid
Default RE: Capiche 50
Ok, well Ill go for the proper stuff, I dont mind the drying time, I'll probably have the pics of the Capiche in its current dodgy state and cowl job tomorrow. Trying to fit that cowl over the fuz upto the point it shows in the plan is a bit iffy, a real tight fit!
Things to do are:
-Fuel proof, reinforce front end
-Fill gaps front end
-Wait for bolts from IH
-Install engine mount and engine
-Sort out tank height in relation to carb intake
-Use the 20 metres of bubble wrap I have (not lying here) to jam everything together
-Try to figure where how the hell am I going to get a throttle run going, I couldnt find the throttle cable, looks like some long pushrod is needed.
That should do the front end then COVER!!! Oh sand and fill before that of course.
trying to cover the tank bay lol. that would be fun
I see what you mean but I had always thought you fuel proofed the outside, not the inside.
