RE: Need a VERY STRONG DIFF for a FR.12 in a XXX-NT
no the but you should have used the search button because this answer has been posted numerous times.
Get the RRP gear.
new balls, and new rings, have a fresh rebuilt differentail, oh yeah get the losi white grease because the aluminum differential has the "broken in" feel so the balls will just about slide righ through it, so you need the grease to keep them in place when you put it together.
Remember you can still run the the stock differntial, just keep in mind your SLIPPER has to slip before your DIFFERNTIAL does.
