RCU Forums - View Single Post - Viper Jet
Thread: Viper Jet
Old 06-22-2004 | 08:37 AM
Miguel Santana's Avatar
Miguel Santana
Default RE: Viper Jet
Gary
The new Viper is comming with the same color scheeme we all know, but also is suppose to come in full white so you can make your own finishing. Not sure if other color are going to be available.
Tam told me the new vertion will also have internal "H beam" spars. Also all control surfases will use regular pivot point hinges, the aluminum wing spars are longer and another big change is that now it will come ready to use off set struts without the need of bending them aft....beleave me, this is important.
The instruction now will show you as an option how to make the speed brakes and they will come already marked at the fuselage for cutting purpose.
I would like to propose Tam a VIPERJET for a P-160, with more scale details. No pictures show you how beatifull this jet is, until you got the chance to see it in person.
Knock, knock....Ehad, are you around?
Regards,
Miguel
