RE: Genesis Breakin
NX76 Engine Set-up and Tuning Instructions
The NX76 is one of the most powerful model engines on the market today. Please take your time and follow these instructions carefully. These instructions are to ensure a long engine life and reliability.
Engine Break-in Procedures
The NX76 engine comes pre-set from the factory for the break-in process. You may need to adjust the idle screw slightly to keep it idling smoothly during the break-in process.
Start breaking in your engine by idling a minimum of 7 tanks of fuel. It’s important to allow the engine to cool down completely between each tank.
After you have idled 7 tanks you can now start to drive the truck around easily. Slowly start to lean the engine out. Lean the main needle adjustment 1/4th of a turn each tank for 2-3 tanks. Drive around in a circle smoothly rolling the throttle on and off. Try to avoid revving the engine up too high. Do this for 2-3 tanks of fuel. Let the engine cool off completely between each tank.
At this time your engine is broken-in and ready for final tuning. These setting will vary depending on where you are running the truck at and with type and brand of fuel. Engine temp should remain around 240-250F. Make sure you take the temp at the glow plug. The top of the head will be much cooler and not give an accurate temp reading for the engine. Here are settings that we end up using after the engines completely broken-in with 20% nitro fuel. Your settings will be different but this should be close.
Main Needle, 3 ½ turns out
Bottom Needle, 2 ½ turns in from flush.
Idle Screw, Adjust to keep engine idling smoothly.
Helpful Tips
Here are tips to help you tune your engine. Use these tips as a reference to help you fine-tune your engine. When making adjustments to the carburetor use small 1/8th turns at a time. Remember that the leaner you run the engine, the more power it will produce up to a certain point; then it will overheat and cause permanent damage to the internal parts of the engine. The overall life of the engine will also vary depending on how hot and hard you run it. If performance is what your looking for then you can decide to run the engine towards the higher end of the temp scale. If you want your engine to last a long time then run it on the lower side.
