RE: Generator
swk551, that eclipse loks very similar to my smaragd, what weight did your's come out at, I'm hoping mine will be under 10lbs, but definately under 11lbs. I'm using a 10s2p pack, so I'm hoping that will produce a light plane.
tonyf
I've mount the motor to the nose ring of my plane, hope it's strong enough, however have you put any form of soft between the motor and fuse. I've been thinking of putting some innertube im between just to dampen the noise from the gearbox.
