RCU Forums - View Single Post - US 60 and 3D??
Thread: US 60 and 3D??
Old 07-15-2002 | 03:04 AM
Flatspin-RCU
Default US60
I have my us almost read to go...just need to install the tank which I'm putting back as far as possible to the cg. I have a os120 pumped on mine...only motor I had left in glow and I didnt have 280.00 dollars to spend on a Saito 100. put a 16x8 apc on it and have almost 2 in of ground clearance...Jim...I think they gave you a 40 size landing gear.. 8^) I mounted the HS buy putting two blind nuts inside the rudder pocket and drilled through the Hs . soaked the balsa with ca to harden it up a little...if the plane flys ok I'll just remove the bolts add epoxy and bolt it back....I'm off work tomorrow so might get it done for a test flight. think the 120 will be enough power? bfg
Ron
