RCU Forums - View Single Post - MonoKote, problems taken care of?
Old 06-24-2004 | 09:04 PM
  #45
newbieT's Avatar
newbieT
Default RE: MonoKote, problems taken care of?
There's a few other posts about covering, some with up to four pieces on each wing half in a certain order so the seams aren't windward. Thanks about my covering job, it is my first and although not as great as some I've seen, I'm still quite proud of it!
So here's another pic of the completely (but not completed) covered wing from my favorite angle. The wing tip got washed out because of the flash, but it's yellow with the black trim. The ailerons got a bit messed up, and I'm upset about it [:@] I drilled the holes for the torque rods and cut the notches out so everything was fitting perfectly...until I did the bevel. Here in the bottom pic you can see what I mean. So for you experienced builder/flyers out there, is this going to be a problem???
-Dave
PS: See the mess I have to clean!? hahaha []
ID:	147066   Click image for larger version
