AC, you weren't using an MK bellcrank were you? For some reason, I've heard about a LOT of elevator systems failing on the T2K using the MK bellcrank. Watched one happen myself, then a friend watched one go down while practicing at the Nats, and I know of about 6-8 others. That system doesn't work on this plane for some reason.
If it wasn't, well that's just bad luck. It sucks eitehr way [
-Mike
