RCU Forums - View Single Post - Electrified Partner
Old 06-25-2004 | 09:02 AM
  #149
Magne
Default Charging Lipo's
Hello.
Do you recommend/need to cool down the batteries after flights, before they are put on the charger?
I have two large lipo packs, 10s2p Irate (4400 mAh total) and 10s3p TP (6000 mAh). After a flight, it takes at least 15 minutes for these packs to cool down to near ambient temperature. I have a cooling tube with a 12V fan that I used to use for charging NiCd batteries, should I start using this before charging?
(The batteries do not heat up at all during charging, so it would just be to get the temperature down as quickly as possible after flights, before charging.)
Magne
