ORIGINAL: navpro
Hello!!! Could someone tell me how to balance a prop??? Do I sand any off the tip, leading edge, trailing edge, or what??? Thanks....
If your talking about plastic props,trim the edges so they arn't sharp,from what i have heard some people remove material from the (front) leading edge but the proper place is the (back)trailing edge usually where it's the thickest.Others will give you more hints.
