How to balance a prop??
ORIGINAL: navpro
Hello!!! Could someone tell me how to balance a prop??? Do I sand any off the tip, leading edge, trailing edge, or what??? Thanks....
Dip the light end in a bright colored paint (@1/2") then sand the paint off the back side to balance. This will also give you a nice splash of color to show you where the whirling razor blades are so you keep all your fingers!
My Feedback: (17)
I don't run anything larger than a 12" prop, but what works for me is trim sheet. I use red/yellow or white, and cut small pieces, so they wrap around the leading edge of the prop and almost meed at the T.E. Works great, and I haven't had one come off yet.
Andy
Andy
IA
This is the best information I have seen on balancing props......
http://www.masportaviator.com/ah.asp?CatID=2&ID=37
PA
