RCU Forums - View Single Post - Rascal W/LA46
Old 06-30-2004 | 09:06 AM
fun4me2fly
Default RE: Rascal W/LA46
Spastic, The 46 is broke in.Yesterday I replaced that engine with a smooth running OS La 40. Same problem,dies on final approach to landing. Never had this problem before with these two motors.And yes I adjusted the airbleed screw out 1/2 turn at a time.I had it almost falling out. In the Rascal the engine is inverted. This and the carb turned 180 degrees is not working.I will make a fix by moving throttle linkage to the other side and turning carb forward.
Thanks for your help Don
