RE: Reverse module
i liked the reverse except for one MAJOR thing. the smallest gear in it is the one that breaks,(i've done it twice). it's probably a two $ gear however to replace it you have to buy the whole gear set. it cost me 45$ for the reverse and a gear set is 35$ and all i needed was the little gear. when you do use reverse use it only for backing out of trouble, and never give it a full speed run in reverse that little gear isn't mounted on any bearrings, just a small shaft.
