RCU Forums - View Single Post - servo can't return to horizontal position
Old 06-30-2004 | 08:58 PM
JohnY2004
Default servo can't return to horizontal position
I don't know what happened to my aerohawk. during a preflight check, when i tested the right aeliron, the servo pushed up and just stayed there and mede the "ssssiiiiii" noise, it couldn't return back to level position. When the joint rods tilted a swash plate to the right or forward, the main shaft moved up a little bit. Does this mean the main shaft will separate from the main gear soon? pls help. thanks
