RCU Forums - View Single Post - Best aluminum primer for scale planes
Old 07-01-2004 | 04:04 PM
SST
Default RE: Best aluminum primer for scale planes
You'll need a primer containing Zinc Chromate to get a good bond to the aluminum. The Latex should be compatible with just about anything, unless it's a laquer base, in which case you must use a laquer primer.
