RCU Forums - View Single Post - Cowling Problems
Old 07-21-2003 | 05:27 PM
Bottlelot_1stAB
Default Cowling Problems
Thanks for all of your help, I am going to use the second suggestion of sanding down the fuse. The cowl flap idea would work perfectly if the cowl flaps were located on the cowl seam, they are actualy located on a lower lip area. Otherwise I would have used this suggestion. Thank you both for your help.
