RE: Frame for carting around plane in back of pickup???
Hi Torp, I do like your ideas with the PVC and I think I will be using yours as my base frame with a couple mods here and there that I am thinking of.
My question is do you put it on the wood while in your truck so that it does not move around or was the wood just there when you took the photo? If you do use the wood how do you fasten the PVC to it?
I have to say I think I like the PVC method best.
Another question for you Torp... did you glue yours all together or is it so that you can take it apart when ever you need. I wonder this because I would not want it falling apart while hanging on the wall if not glued.
